  3. compatibility of Assura 3.1 for 65 nm process
  • Subscribers 132
  • Views 15322
Jithin
Jithin over 13 years ago
    I have been using Assura 3.1 for DRC,LVS  and extraction for 0.35 um cmos process and now we have been using 65 nm process.
Does this Assura is capable for  DRC, LVS and including extraction for 65 nm cmos process.
    First of all, Assura 3.1 is no longer supported. The currently supported version is 4.1, so you really should use that. That's the only version available on http://downloads.cadence.com .
    Secondly, it's not really a matter of Assura 3.1 being "capable" for 65nm. What matters is whether the foundry you're using has qualified it for their specific 65nm rules. But I really would suggest you install 4.1. There really is no good reason to use an old version.
  • Jithin
    Thank you for your kind reply. Regards, Jithin
