  3. Plotting through calculator
  • Subscribers 132
  • Views 17524
Jithin
Jithin over 13 years ago
I have been plotting a Ids vs Vds curve of nmos in 65 nm process and been saving all the parameters using the script "save M0.m1 :all" but the problem I am facing is that when I try to plot the current of transistor throgh the calculator an error is coming saying "Illegal expression . Is it because I have selected the subcircuit parameter.
 Thanking you.
Jithin K
    Hi Jithin,
    Without seeing the expression you used, it's going to be rather tricky to know what is wrong!
    Please read the Forum Guidelines.
    Kind Regards,
  • Jithin
    HI,
    Thank you for the faster reply once again.
    What I have been doing in my design is just sweeping the gate voltage of an nmos transistor(65 nm cmos process), while keeping the transistor in saturation. The problem I have faced while doing experiment is that I was not able to plot the output using calculator even the current through the transistor. I had include the ".scs" file(save M0.m1:oppoint) for keeping track of the device current at all gate voltage and when I tried to plot it calculator is saying that "Expression evaluation failed :Expression evaluatees to nil". But when I double click on the result we are getting the plot.
    The expression given in the calculator was :  getData("/M0/m1:id"? result "dc-dc")
    Thanking you once again.
    Jithin
    This looks suspiciously similar to this thread.
  • Jithin
    Thank you for your reply. Yes that seems to be same problem. Regards, Jithin
