  3. Need help for dracula lvs!!!
  • Replies 8
  • Subscribers 132
  • Views 18981
cpygczy
cpygczy over 13 years ago
 Dear all,
After I ran ./jxrun.com, it displayed that:
 */N* AT STAGE: 33
 */N*  LVSCHM   (REV. IC6.1.5.08-2010     / LINUX         /GENDATE: 30-AUG/2010)
                    *** ( Copyright 2010, Cadence ) ***
 */N*  EXEC TIME = 13:55:53    DATE =  1-JUN-2013   HOSTNAME =      ubuntu
 BIG NODE LIMITS:      30000         150            KPQUE =     2
 */L*      6NETS    (6PADS   )  AGAINST  6NETL    (6PADL   )
/home/international/Cadence/IC615/tools.lnx86/dracula/bin/32bit/LVSCHM: symbol lookup error: /home/international/Cadence/IC615/tools.lnx86/dracula/bin/32bit/LVSCHM: undefined symbol: dbm_open
How to solve this problem?
  • cpygczy
    After I run   ./jxrun.com, an error occured like this:
    I believe this function comes from the "gdbm" shared library - running "ldd" on the LVSCHM executable suggests to me that it's from there:
             linux-gate.so.1 =>  (0xf7782000)
            libgfortran.so.3 => /usr/lib/libgfortran.so.3 (0xf76ab000)
            libm.so.6 => /lib/libm.so.6 (0x00522000)
            libnsl.so.1 => /lib/libnsl.so.1 (0x0067a000)
            libdl.so.2 => /lib/libdl.so.2 (0x0051b000)
            libgdbm.so.2 => /usr/lib/libgdbm.so.2 (0xf76a3000)
            libtermcap.so.2 => /lib/libtermcap.so.2 (0xf769f000)
            libelf.so.1 => /usr/lib/libelf.so.1 (0xf7687000)
            libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x0056b000)
            libc.so.6 => /lib/libc.so.6 (0x00389000)
            /lib/ld-linux.so.2 (0x00367000)
    My guess is that your OS has an outdated or incorrect version of libgdbm.so.2 (I've seen one report saying that this doesn't work on SuSE, but I've got nothing to back that up). I see from your hostname that you are probably using Ubuntu, which is an unsupported operating system - so maybe that's the root cause?
  • cpygczy
     Thank you very much!
    My version of libgdbm.so.2 is libgdbm.so.3. I linked them. Could you send the correct version to me
    My E-mail address is cpy.international@qq.com.
    International.
  • skillUser
    skillUser over 13 years ago
     Like what?  Go to the Options tab to add attachments.
  • skillUser
     Oh, and please don't re-post a question as a new thread (read the Forum Guidlines)
    I cannot send you parts of the OS - it would (I believe) break our license agreement. You should be able to download the relevant package yourself though for the particular distribution you're using. Note however that if you're using an unsupported OS, you may hit other issues... unsupported means that we've not tested on that OS.
  • cpygczy
     Sorry!
    I'm from China. I'm not good at English. I can't understand you. What did you mean?
  • cpygczy
    I have solved the problem!
    You are my hero!
