  3. Any way to use ADE variables in Hierarchy Editor ?
  • Subscribers 132
  • Views 15341
kentauta
kentauta over 13 years ago
Is there any way to specify views to use using ADE variables in the Hierarchy Editor?  Alternatively, can we specify the simulation target using a variable in a test in ADE-XL?  This would allow us to simulate over layout extraction corners using one test in ADE-XL.
Currently, we have a config view for each layout extraction corner (like config_cmim, config_typ, config_cmax) and have a dedicated test for each (like test_cmin, test_typ, test_cmax) in ADE-XL.  It is really cumbersome to manually apply the same change to all of the tests each time I want to make a change to the tests.
Thanks!
    No, it's not possible currently. You can make the view switch list (if not using a config) a variable (I think), but you can't reference ADE variables in config views. You might want to contact customer support over such a requirement so that an enhancement request can be filed.
    Kind Regards,
  • kentauta
    kentauta over 12 years ago
    Thanks, Andrew.
    Yes, some of the folks here put a variable in the switch list, but as you mentioned it doesn't go with config views, which is a problem for most of my simulations.
    I will filea request to the customer support.
    kentauta
