  3. Cadence IC5.141 with NCSU design kit 1.2 or 1.5
  • Subscribers 133
  • Views 15581
archive over 19 years ago
I recently updated the cadence IC from 5.033 to 5.141 and now I could not change any device parameters in the schematic. I am using NCSU CDK 1.2 and have also tried it with version 1.5. Things were working fine before the upgrade.
Any suggestions?
Originally posted in cdnusers.org by gte558w
    Which subversion of IC5141 are you using? I recall there were some problems with callbacks in the schematic editor around IC5141 USR2, which in certain situations prevented parameter updates.
    Can you be a bit more specific about what you're doing that doesn't work?
    Originally posted in cdnusers.org by adbeckett
    sub-version 5.10.41.500.3.31 (32-bit addresses)
    I am using the above subversion. I did something that fixed the problem at least in NCSU CDK 1.2. Still CDK 1.5 is not working for me. All I am trying to do is change W & L parameters. Whenever I change it, it goes back to its original values.
    Shakeel
