  3. An urgent problem with the design rule check using Assu...
  • Subscribers 132
  • Views 15248
An urgent problem with the design rule check using Assura
UUinfini
UUinfini over 13 years ago
When I use Assura to do the design rule check after I have done layout using the C35B4 technology in Cadence, there is always a following probleme:
[1] #INFO: C35B4/C35B3 ASSURA DRC DECK(REV9 DATE 26-Apr-2011) Last modified 15-Jun-2012.
 does anyone know why? Thank you advance for you response.
    Did you try contacting whoever provides this technology (I don't know who it is from the name; I can probably guess, but the rule files come from the foundry in question, so best to ask them).
    Maybe they always generate an "error" to indicate the version you're using?
  • UUinfini
    Thank you for your advice, I will ask this.
