  3. Updating instances in Layout XL
  • Subscribers 132
  • Views 15251
Siddique baig
Siddique baig over 13 years ago
Hi All,
 I have a block with LVS clean. Few of the transistors are highlighted in the layout when clicked on them in schematic (I am using Layout XL in Virtuoso 6.1.5 version).
Other transistors are not highlighted when clicked on them in schematic. This is because I have made a unit cell and copied the same in the layout to save time. I can go through "Define Device Correspondance" in Connectivity menu to fix the correspondance between layout and schematic. But, there are huge number of such devices.
So, I would like to know If is any method which compares the connections between the layout and schematic and updates the device correspondance automatically. Is there any skill code or command to do the above task?
Thanks in Advance,
Baig.
