  3. Using db objects in replay file
  • Subscribers 133
  • Views 16728
egolowen
egolowen over 13 years ago
I am trying to use SKILL code in order to generate a bunch of commands (which go into a replay file) to move instances in my layout (using the dbMoveFig function).
I am having issues with the db object inside of the command itself. For example, something like this:
          dbMoveFig(db:0x27db609b nil list(-2.020000:4.300000 "R0"))
generates an error.
Is there some way to include a specific db object in the commands in my replay file without generating errors?
Elizabeth
  • Quek
    Quek over 13 years ago
    Hi Elizabeth
    Using the ID of a figure in dbMoveFig cmd is the correct approach but we should not use the ID directly. A variable containing the ID should be used. E.g.
    a. Select a layout object
    b. Execute the following:
    obj=car(geGetSelSet())
    dbMoveFig(obj nil list(...))
    Please let me know if I have misunderstood your question.
    Best regards
    Quek
  • Quek
    Hi Elizabeth
    By the way, questions on SKILL programming can be posted to the SKILL forum.
    Best regards
    Quek
  • egolowen
    Hi Quek,
    Unfortunately, I am not selecting any of the instances I am just looping through all of the instances in the cellview and moving them:
    foreach (inst cv_layout~>instances
         dbMoveFig(inst nil ...)
    and using obj = car(inst) does not work in this case. Is there anything I could use without having to actually select the instance?
    Elizabeth
  • Quek
    Hi Elizabeth
    There is no need to use "car" cmd or to select the instance if you are already looping through the individual instance IDs. You can use this:
    foreach( inst cv_layout~>instances
    The above should work. Would you please let us know the specific error message if it still does not work?
    Best regards
    Quek
  • egolowen
    Hi Quek,
    These are the commands and error I am getting:
    dbMoveFig(db:0x1ea7641d nil list(-2.020000:4.300000 "R0"))
    *Error* eval: unbound variable - db
    dbMoveFig(db:0x1ea7641c nil list(-1.140000:4.300000 "R0"))
    dbMoveFig(db:0x1ea7641a nil list(-0.255000:4.300000 "R0"))
    dbMoveFig(db:0x1ea7641f nil list(-2.820000:4.220000 "R0"))
    dbMoveFig(db:0x1ea7641e nil list(-1.140000:4.220000 "R0"))
    dbMoveFig(db:0x1ea7641b nil list(0.540000:4.220000 "R0"))
    Elizabeth
    If you're getting that error, you can't be using the foreach as Quek suggested. You must be literally using db:xxxxxxxx as the input to the function. You can't do that, and it is never necessary to do that.
    The dbIds are per-session and may not be the same (quite unlikely to be the same) between different invocations of virtuoso. Also, the dbId is the "print representation" of the dbId, and only output to allow you to see that it's a dbId and whether it is the same as another dbId in the same session (for example).
    So why are you trying to enter literal dbIds rather than using a loop (you said before you were using a loop)? Maybe you're generating this replay file programmatically? If so, put the loop code in the replay file rather than references to the objects.
