  3. spectremdl and "print fmt" function
  • Subscribers 132
  • Views 3069
samung
samung over 13 years ago
Hello !!
I would like to use the "print fmt" function of spectremdl, however, I have not managed yet in printing something in an ouput file with this function.
I have written some extracted data from a transient simu with export command but the "print fmt" doesn't work for me.
I would like to better configure what is inside the results_file, meaning removing the default template :
"Exported variables from results directory:  ./input.raw
date               :  31:18:59 AM, Wed Jun 19, 2023
design             :  (no title)
simulator          :  spectre"
I launch : spectremdl -batch input.mdl -design input.scs -measure results_file +log log_file.log
I have the following input.mdl file :
/* mdl measurement file */
alias measurement run_tran_simu {
input string out="aaa/bbb/ccc/results_file"
run tran
export real out_value_50n = V(out)@50n
export real out_value_0 = V(out)@0
export real diff_out_50n_0 = abs(V(out)@50n - V(out)@0)
print fmt ("****Cell functionnality : TEST****") addto=out
if (diff_out_50n_0 > 1)
    print fmt ("****Cell functionnality : GOOD****") addto=out
else
    print fmt ("****Cell functionnality : BAD****") addto=out
run run_tran_simu
and the following results_file :
date               :  31:18:59 AM, Wed Jun 19, 2033
design             :  (no title)
simulator          :  spectre
Measurement Name   :  run_tran_simu
Analysis Type      :  tran
diff_out_50n_0     =  1.1
out_value_0        =  1.1
out_value_50n      =  4.89856e-06
NB : we don't see any "print fmt" written stuff !!
The log file is clean :
sam@clust:/xxx/yyy/.../zzz> grep -i error log_file.log
spectre completes with 0 errors, 0 warnings, and 3594 notices.
How can I do to use this "print fmt" function with success ? How can i customize the "template" of the results_file ??
Thanks !!
P.
    It does work - but the issue is that it would try to write into the file called: "aaa/bbb/ccc/results_file" (the definition of the out variable at the top). If this file is not writable, it won't write it. It certainly would not write it into the conventional output, because you used addto=out.
    I tried changing out="results_file" and that worked perfectly.
  • samung
    you are right, if I change to : to=out & input string out="results_file" as below it works :
    .mdl :
    run tran
    print fmt (\"****Cell functionnality : TEST****\") to=out
    However, I would like to write the string (print fmt) in a file defined by something like : "/aaa/bbb/ccc/results_file"
    The commandline is :
    spectremdl -batch /aaa/bbb/ccc/input.mdl -design /aaa/bbb/ccc/input.scs -measure /aaa/bbb/ccc/results_file +log /aaa/bbb/ccc/log_file.log
    For the export commands, it works well. Indeed, the output file for the export commands is defined by : -measure /aaa/bbb/ccc/results_file.
    So the output file exists. However, for the "print fmt" command and the "to=out", the file doesn't exist yet. I tried removing the input string out="results_file" with straigth print fmt (\"****Cell functionnality : TEST****\")  to=/aaa/bbb/ccc/results_file, and it doesnt find the file.
    The question, is : is it possible to write both the export and the print fmt commands in the same results_file, which is created by the  spectremdl -batch /aaa/bbb/ccc/input.mdl -design /aaa/bbb/ccc/input.scs -measure /aaa/bbb/ccc/results_file +log /aaa/bbb/ccc/log_file.log command ?
    Thanks !!
    P.
    You can certainly write to aaa/bbb/ccc/results_file , provided that the intervening directories exist already.
    However, you can't write to the same file as the -measure file is pointing to - this is because both outputs will compete with each other - and I think the -measure results win. There's no facility that I can see to also print to the same file as the -measure specification.
    If that's what you want, you should contact customer support for an enhancement request.
    Kind Regards,
