  3. How to plot the verilogA module data points using OCEAN
  • Replies 9
  • Subscribers 132
  • Views 18498
RFStuff
RFStuff over 13 years ago
 Dear All,
I used a verilogA module in my schematic which measures the period of the output  waveform of a block.
The verilogA code is as follows:-
`include "disciplines.vams"
(*instrument_module*)
module frequency_meter(in);
    parameter real thresh=0;    // threshold (V)
    parameter integer dir = 1 from [-1:1] exclude 0;
                // 1 for rising edges, -1 for falling
    input in;
    voltage in;
    integer timing;
    real t0, t, period, freq;
    analog begin
    t = last_crossing(V(in) - thresh, dir);
    @(cross(V(in) - thresh, dir)) begin
        if (timing) begin
        period = t - t0;
        freq = 1/period;
        $strobe("period = %rs (measured at %rs).\n", t - t0, $abstime);
        end
        t0 = t;
        timing = 1;
    end
    end
endmodule
I want to plot freq versus time  using OCEAN script.
Can anybody please tell how it can be done.
I did :
save I5:period I5:freq
plot(I5:freq).
This gives error in OCEAN script.
But in input.scs file I worte:-
I ran the simulation and in the wavescan I was able to plot freq-vs-time.
Kind Regards,
    In the spectre netlist, you can add:
      myOpts options saveahdlvars=all
    or in OCEAN you could say:
      saveOption( ?saveahdlvars "all" )
    And then to reference the freq signal, you'd do:
      plot(getData("I5:freq" ?result 'tran))
    Or you could make the frequency an output pin of the meter instead - but that involves changing it a bit so that you are contributing to a node - for your needs the above is probably sufficient?
    Best Regards,
  • RFStuff
     Dear Andrew,
    Thanks a lot.
    Now, I am beginner to verilogA coding.
    I have some doubt regarding the above verliogA code.
    1:- $Strobe prints at what instants
    2:- Looks like it is printing even if there is NO thresold cross
    Kind Regards,
     It should print when there's a threshold crossing and timing==1. That's what I see. Are you sure you don't have threshold crossings?
  • RFStuff
    Dear Andrew,
    Theree are thresold crossings. But it is printing ( what is inside  $strobe )even between the  zero crossings.
    To me it looks like it is being printed at the end of  each simulation time step ? This I am not able to understand.
    Kind Regards,
    Can you put together a simple example (just with voltage sources, analogLib res/cap) which shows the problem? Then post the input.scs (also the version of spectre that you're using).
  • RFStuff
     Sorry Andrew,
    I misinterpreted the result. It is printing as you have mentioned.
    1:-  I have some doubt regarding the initial parameter value of  "t0" and "timing" in the 1st iteration.
    2:- Could you please tell what change I have to make to make freq as an output node in the code ?
    3:- Could you please tell how to plot it in GHz unit instead of GV ?
    Kind Regards,
    1. The initial values will be 0 - this is in the VerilogAMS language definition.
    2 & 3 - see the model below. By specifying the output as a frequency discipline, the graph comes out with the right units too (I'd not seen your third point until I'd updated the model, but it solves 3 too...)
    // could specify the fout signal as being electrical
    // but it's nicer to do it as the specific discipline - this
    // way we can have a custom abstol and blowup, since the
    // magnitude of the frequency will be much larger than
    // voltages in the circuit
    nature Frequency
        units="Hz";
        access=Freq;
        abstol=1;
        blowup=100G;
    endnature
    discipline frequency
        potential Frequency;
    enddiscipline
    module frequency_meter(in,fout);
        input in;
        voltage in;
        output fout;
        frequency fout;
        integer timing;
        analog begin
            if (timing) begin
            period = t - t0;
            freq = 1/period;
            end
            t0 = t;
            timing = 1;
        end
        // use a transition filter to ensure that the frequency doesn't
        // change discontinuously
        Freq(fout) <+ transition(freq,0,100p);
        end
    endmodule
    Kind Regards,
  • RFStuff
    Dear Andrew,
    Thanks a lot.
    Whether setting abstol and blowup in this code affects the accuracy.
    Actually, I am seeing some differnece in the frequency plots ( i.e. periodic spike ) in this code as compared to the code ( without having a pin)
    Kind Regards,
    blowup won't, abstol might. Depends on what frequencies you're dealing with - ideally abstol should be about a millionth of a typical frequency that is being measured.
    Also, the transition time should not be excessively sharp if the frequency is low. Or it may be too short - I don't know what frequency ranges you're dealing with.
