  3. ADE calculator function question
  • Subscribers 132
  • Views 16544
potsticker
potsticker over 13 years ago
hi,
i have a question about calculator function.
Q1: i used to use in hspice the .measure statement of
find v(a) when v(b)=v(c)
but i don't know what function could acheive the same function in the ADE calculator.
Q2: i am also trying to find the delay from when
v(b) crosses v(c)     to when v(a)=0.9v (for example)
how can i do this in the calculator?
I appreicate any help. thanks.
Frank
    Frank,
    Something like this:
    A1. value(VT("/a") cross(VT("/b")-VT("/c") 0.0 1 "either"))
    A2. cross(VT("/a") 0.9 1 "either")-cross(VT("/b")-VT("/c") 0.0 1 "either")
  • potsticker
    thanks Andrew, i  will give it a try now.
    is there a way to tell the calculator to wait T seconds, before doing the evaluation?
    Frank
    Why would you want to do that? Sounds a bit odd to me... (there is a way, but I doubt very much that this is really what you want to do). Perhaps you can explain exactly what you're trying to do?
  • potsticker
    hi Andrew,
    it is because it takes 10us for the transient waveform to stabilize to generate proper waveform.
    thx
    Frank
  • potsticker
     hi Andrew,
    i was able to later use the delay function which allowed me to specify the start time for the measurement. thanks.
     Frank
    Frank,
    Ah, I thought you were talking about a real time delay rather than simulation time...
    You can also use functions such as clip to extract just a portion of the waveform.
    Kind Regards,
