  3. analysis
  • Replies 29
  • Subscribers 132
  • Views 27293
analysis
yeong
yeong over 12 years ago
hello
  • yeong
    Andrew,
    Everything works fine. Thanks.
    Another question:
    In ocean, how can i save the all corners simualtion results in a directory and retrieveit later? I tried to plot the from result brower, but it only save the last run.
    y
  • yeong
    i used this to group model corners togther, but what should i do for the variable, such as temp, iled, etc for model corners i use: myResultsDir=strcat("/xxx" corner) resultsDir(myResultsDir) y
    Why not just use something like:
    sprintf(myResultsDir "/xxx%s_%d%g" corner temp iled)
  • yeong
    Andrew,
    This works, however the file name doesnt match the variables used.
     I have to use  sprintf(myResultsDir "/xxx%s_%d%g" corner y1 y2) instead. In this case the file name matches the variable.
     Any reason why?
  • yeong
    Andrew,
    I want to print my output as follows:
    corner temp iled i differential_psrr etc etc
    tt_lib    -40   1m 1u 60.34  xx xx
    I tried to use fprintf instead of ocnPrint. Simulation completed without error, however there is no data in the output file. There is no problem using ocnPrint, just need to organise it a bit in excel.
    This is what i use:
    fprintf(out "corner\ttemp\tiled\ti\tdifferential_psrr\n")
    fprintf(out "%s\t%d\t%g\t%g\t%g\%g\n")
    Also, I have quite a bit of expressions, how can i output the data in a more efficient manner?
    y
     Any reason why?
    This is because the SKILL variables in your script are called y1 and y2. I wasn't looking at your previous code when I replied - I assumed you had SKILL variables (not design variables, which correspond to spectre parameters) called iled and temp etc.
    If this is what you are using, it ought to fail with an error, because there are no arguments corresponding to each % keyword in the formatting string.
  • yeong
    sorry, i forgot to include the arguments in the post.
    fprintf(out "%s\t%d\t%g\t%g\t%g\%g\n" corner temp y1 y2 differential_psrr )
    the arguments as declared in the script previously.
  • yeong
    this is the script. simulation runs fine, but no data in test.txt
    ocnWaveformTool('wavescan )
    simulator( 'spectre )
    out=outfile("test.txt" "w")
    design(     "/xxx/spectre/schematic/netlist/netlist")
    ;resultsDir( "/xxx/spectre/schematic" )
    analysis('ac ?start "1"  ?stop"1G"  ?dec "50"  )
    analysis('dc ?saveOppoint t  )
    desVar(       "cap_factor" 1  )
    desVar(       "iled" 16m      )
    desVar(       "i" 848u  )
    option(     'temp  "150.0"
    saveOption( 'subcktprobelvl "5" )
    temp( 150.0 )
    myCors=list("ff_lib" "tt_lib" "ss_lib")
    foreach(corner myCors
    modelFile(
    list("/xxx.scs" corner)
    foreach(y1 '(150)
    temp(y1)
    foreach(y2 '(1m 10m)
    desVar("iled" y2)
    foreach(y3 '(1u 5u)
    desVar("i" y3)
    run()
    differnetial_psrr = dB20((VF("/psrr") - VF("/ref")))
    plot( differnetial_psrr ?expr '( "differnetial psrr" ) )
    differential_psrr_3dB_BW = cross(dB20(VF("/psrr")) (value(dB20(VF("/psrr"))1) + 3) 1 "either" nil nil)
    ;plot( differential_psrr_3dB_BW ?expr '( "differential_psrr_3dB BW" ))
    differential_psrr_dB_DC = value(dB20((VF("/psrr") -VF("/ref"))) 1)
    ;plot( differential_psrr_dB_DC ?expr '( "differential_psrr_dB_DC" ))
    differential_psrr_dB_max = ymax(dB20((VF("/psrr") -VF("/ref"))))
    ctr = VAR("ctr")
    iled = VAR("iled")
    fprintf(out "%s\t%d\t%g\t%g\t%g\%g\n" corner temp iled y3 differential_psrr )
    y
    Probably this is because you're not closing the file. In SKILL (as in many other languages), writing ASCII files is buffered (for efficiency reasons) so that it doesn't flush to disk until the buffer is full (or when the file is closed).
    So two choices:
    1. Call close(out) at the end (in fact you should do this anyway to avoid having lots of open file handles lying around)
    2. If you want the output to update more frequently (for example, so that you can see the file contents during a loop where running the simulations takes some time), you can flush the buffers by calling drain(out)
