  3. analysis
  • Replies 29
  • Subscribers 132
  • Views 27304
analysis
yeong
yeong over 12 years ago
hello
  • yeong
    Thanks Andrew, it works perfectly.
     I'm also interested to list all the variable corner temp iled i differential_psrr in a list and fprint them
     variable=list(
    corner
    temp
    i
    foreach(val variable
    fprintf(out "%g\t"  val)
    error mgs:
    Error fprintf/sprintf: format spec. incompatible with data -40
    Corner is a string, temp is decimal, and i is a floating number, how can i lump different outout togther?
    y
    How about:
      fprintf(out if(numberp(val) "%N\t" "%s\t") val)
  • yeong
    What is %N use for?
     that return: synatx error encountered in input
    i tried using:
      fprintf(out if(numberp(val) "%g\t%s\t") val)
     and that return: type template = "ptg"
    y
    I'm not sure what you did incorrectly, because the first form is entirely correct and valid for as long as I can remember in SKILL. I just cut and paste it, and it worked fine. For example:
    variable='("hello" 4.2 27)
    out=stdout
    this worked perfectly. The "%N" (as covered in the documentation for fprintf/printf) is for displaying any kind of number (float or integer). What the code above does is either use %N or %s as the format depending on whether it's a number or not.
    Your second code won't work because it either gives a format which has two format strings, but only one argument, or it returns nil (if not a number) which will give the type template error.
    Kind Regards,
  • yeong
    The script works fine after i tweak the variable values to be all float number. and use %g instead of %N.
    Does it have to do with the version? I'm using version 5.1.0
    I tried the example in CIW,
    out=stdout
    Here's the output
    ("hello" 4.2 27)
    port:"*stdout*"
    hello
    *Error*  fprintf/sprintf: illegal format spec. -"%N\t"
     A bit of tweaking :
    variable='("hello" 4.2 2.7)
    out=stdout
      fprintf(out if(numberp(val) "%g\t" "%s\t") val)
     output as below
    ("hello" 4.2 27)
    port:"*stdout*"
    hello 4.2 2.7
    ("hello" 4.2 2.7)
    y
    Sorry, my mistake. It was "%n" that has been there for years, not "%N". %N uses a more compact notation. So you can either change the %N to %n, or use this code instead:
      fprintf(out "%s\t" if(numberp(val) aelEngNotation(val) val))
    Depending on which looks the nicest to you!
  • yeong
    Thanks andrew.
    It works well now.
    y
  • yeong
    Hello Andrew,
     When using  foreach(val variable
      fprintf(out if(numberp(val) "%n\t" "%s\t") val)
     can i increase the number resolution?
    There is output but it came out as 0.0000, the value i'm expecting is 2e-9 (for example)
     y
    The %n sequence means "use %d if an integer, or %f if a floating point number". In IC615 you can use %N which means "use %d if an integer, or %g if a floating point number". So %N would do what you want; similarly if you know the value is a flonum, you can just use %g. Or if you always want it in exponential format, you could use %e.
