  3. Error in MMSIM when executing on 64bit machine
  • Subscribers 132
  • Views 15413
Arslan
Arslan over 12 years ago
Hi, I am getting following error while executing spectre simulation from a 64 bit machine.
 Can't load '/IC_TOOLS/CADENCE/MMSIM111/tools.lnx86/mdl/etc/perl/cdsPSF.so' for module cdsPSF: libelf.so.1: cannot open shared object file: No such file or directory at /IC_TOOLS/CADENCE/MMSIM111/tools.lnx86/perl/lib/5.8.8/i686-linux/DynaLoader.pm line 230. at /IC_TOOLS/CADENCE/MMSIM111/tools.lnx86/mdl/etc/perl/spectremdl.pl line 236 Compilation failed in require at /IC_TOOLS/CADENCE/MMSIM111/tools.lnx86/mdl/etc/perl/spectremdl.pl line 236. BEGIN failed--compilation aborted at /IC_TOOLS/CADENCE/MMSIM111/tools.lnx86/mdl/etc/perl/spectremdl.pl line 236.
What should I do?
    Do you have these files on your machine?
    /usr/lib/libelf.so.1
    /usr/lib64/libelf.so.1
    The first is the 32-bit version, and the second the 64-bit version. Despite being on a 64-bit OS, the default is for spectre to run in 32-bit mode (you can run spectre -64 to change that, or do "setenv CDS_AUTO_64BIT spectre" before running spectre).
    These are provided by the elfutils-libelf rpm:
    UNIX> rpm -q -f /usr/lib/libelf.so.1
    elfutils-libelf-0.152-1.el6.i686
    UNIX> rpm -q -f /usr/lib64/libelf.so.1
    elfutils-libelf-0.152-1.el6.x86_64
    If you run <MMSIMinstDir>/tools/bin/checkSysConf MMSIM12.1
    (or whatever version you're using) - it should be checking for elfutils-libelf., Are you using a supported OS version?
    Kind Regards,
