  3. Error while running PLL Top simulations with Ultrasim
  • Subscribers 133
  • Views 15386
archive over 19 years ago
Dear all,
I'm simulating PLL top-level. Initially, I used Spectre simulator and the simulations proceeded with no errors. However, it look a very long time. Then, I switched to Ultrasim simulator. While doing simulations with the same test-bench(as used while running Spectre simulations), I'm getting the following error:
****ERROR****: Unmatched double quote for string: tlim/rth)
Could you please help me in sorting-out this issue?
Any help is appreciated.
For your reference, I'm attaching the log file (in MS-Word format)
Originally posted in cdnusers.org by vj
usim_output.doc
    I saw this also with the versions of IC5141 some late ISR and
    MMSIM611.
    It seems to me as a BUG in the netlister, because I got somewhere
    in the netlist ""string"" which could not be interpreted by the
    simulator. Didn't remember if it was Spectre or UltraSim.
    If I switched back to IC5141 USR3 it works again.
    I'll suggest you to use a slightly older version of
    the IC tools or to look in the netlist for "" (double quotes)
    and remove _one_ of them them manually.
    Bernd
    Originally posted in cdnusers.org by bernd.fischer
    Thanks Bernd.
    I checked with the cadence support and they asked me to install the latest ISR - ISR20061204125 for MMSIM.
    -vj
