  3. Ultrasim is not recognising hspice (<) syntax
  • Subscribers 132
  • Views 1354
Ankumar15
Ankumar15 over 12 years ago
Hi ,
I am running Ultrasim on hspice control file. I have following syntax in the hspice and Ultraspice does not like "?" . Error message says that "Unexpected ternary operator "?" .
My hspice deck is
.measure tran  v_out  find V(out) at=5n
.measure result param='(V_out > 0.4)?1:0'
Please let me know if you know how to resolve this issue.
I am trying to validate  that whether V(out) is greater than 0.4V at 5ns , if yes then declare 1.  I have 10 bit to 1024 decoder and I am trying to make sure that circuit is deoding properly .
If Ultrasim has similar function/syntax then it will be a great help.
Anil K.
    Anil,
    In this specific case, it would be sufficient just to use:
     .measure result param='(V_out > 0.4)'
    You might want to contact customer support to get the ternary operator supported in .MEASURE statements.
