  3. ADEXL tabulating for 20 hours!
  • Subscribers 132
  • Views 15189
ukelkar
ukelkar over 12 years ago
I am using ADE, Version IC6.1.5-64b.500.6
and running 66 cross corner sims. At sim 36/66, the simulator ponders for 20 hours without proceeding to the next simulation. There is enough disk space and there are no errors that I see. How can I prod the simulation to proceed?
 I do not want to throw away the first 35 sims that have been saved.
Uma
    Uma,
    First of all, in the Outputs Pane, go over the run that is running, and do Right Mouse->Output Log and see if the simulator is running and what it is doing - maybe the simulation has stagnated because of an unusual corner condition causing convergence difficulties?
    If that doesn't help, then in the Run Summary assistant (see the attached picture), there will be (at least one) terminal window for each running "ICRP" process. You can click the Right Mouse button over this and get a popup of the job log - near the top you'll see info such as this:
    \# Initial memory used:    36659200 (0x22f6000) bytes
    \#        process size:    374894592 (0x16587000) bytes
    \# Qt version:        4.5.3
    \# Window Manager:    other
    \# User Name:        dummyUser
    \o Working Directory:    dummyHost:/export/home/dummyUser/demos/OCEAN
    \# Process Id:        18231
    From this you can see the process id - and you can kill this process id (from a UNIX terminal, using the kill command). Maybe there is some reason why the ICRP has got stuck (maybe it says down the bottom of the log file). Generally if the ICRP is killed, it will restart it and try again.
  • ukelkar
    Thanks Andrew, I did what you told and I was able to kill just the ICRP process and the simulator restarted and got stuck in tabulating mode again. I checked if it was a specific corner issue, but I could prove to myself that corner/license issue did not exist.
    The best thing would be to contact customer support so that we can investigate properly.
