  3. Problem in creating logic to electrical connect module in...
  • Subscribers 132
  • Views 16313
Problem in creating logic to electrical connect module in verilogams
indra0804
indra0804 over 12 years ago
I am trying to make a logic to electrical connect module that can convert logic ( '1' or '0') at the input side to electrical pulses at the output side, implementing in verilog-ams, its required for one of the project that I am doing. But, the problem that I am having is that, its running and simulation is taking place, but irrespective of whether I give '1 or a logic '0'', the output is staying at 818.18mV. My Vhigh= 1.8 V and Vlow= 0v.
I am attaching the code that I am trying to implement....
`include "disciplines.vams"
`timescale 1ns / 10ps
connectmodule d2a (out, in);
    parameter real v0 = 0.0; // output voltage for a logic 0 (V)
    parameter real v1 = 5.0; // output voltage for a logic 1 (V)
    parameter real vx = 2.5; // output voltage for a logic x (V)
    parameter real vz = 5.0; // output voltage for a logic z (V)
    parameter real r0 = 1k from (0:inf); // output resistance for a logic 0 (Ohms)
    parameter real r1 = 1k from (0:inf); // output resistance for a logic 1 (Ohms)
    parameter real rx = 100 from (0:inf); // output resistance for a logic x (Ohms)
    parameter real rz = 1M from (0:inf); // output resistance for a logic z (Ohms)
    parameter real tr=1n from [0:inf); // rise time (s)
    parameter real tf=1n from [0:inf); // fall time (s)
    input in;
    output out;
    logic in;
    electrical out;
    real v, r;
    assign in = in;
    initial begin
case(in)
   1'b0: begin v = v0; r = r0; end
   1'b1: begin v = v1; r = r1; end
   1'bx: begin v = vx; r = rx; end
   1'bz: begin v = vz; r = rz; end
endcase
    end
    always @in begin
case(in)
endcase
    end
    analog
V(out) <+ transition(v, 0, tr, tf) + transition(r, 0, tr, tf)*I(out);
endmodule
Indrajit
