  3. How to hide "navigator assistant" in schematic by default...
  • Subscribers 132
  • Views 1487
How to hide "navigator assistant" in schematic by default in IC615.500
xhdong
xhdong over 12 years ago
  Is there a way to hide “navigator assistant" in scheamtic editor by default?
I'm using cadence IC615.500. Navigator assistant is useful but sometime I don't want to show it when I open a schematic.
Is there a way to set to hide it by default?
Thanks!
    If you don't want any assistants, change the workspace (in the Workspace toolbar, or using Window->Workspaces->...) to "Classic" and then do Window->Workspaces->Set Default - and save the Classic workspace as your default in either ./.cadence or .cadence under your home dir - depending on where you want the preference saved.
    You can similarly create your own workspace (arrange whichever assistants you want whereever you want), save it as a name, and then make it the default using the approach above.
    And also make sure you're aware of the F11 bindkey which toggles all the assistants on or off.
  • xhdong
    Andrew,
      It does work! Thank you!
    XH
