  3. LVS switches needed for extraction of additional parameters...
  • Subscribers 130
  • Views 14701
LVS switches needed for extraction of additional parameters for MOSFETS in PVS
sohaiba
sohaiba over 12 years ago
Hello everyone,
 Please can anyone indicate the LVS switches required for extraction of intrinsic capacitance etc for MOSFETS in PVS/LVS. I know that for calibre we can use "PEX_RUN=TRUE " to acheive this.
Regards
  • Quek
    Quek over 12 years ago
    Hi Sohaib
    PVS does not extract parasitic capacitance. This is done by the downstream tool QRC. Some foundries use the same PEX_RUN switch in PVS decks to enable the extraction of special lvs parameters. If such a switch is present in your deck, I think you can also enable it.
    Best regards
    Quek
  • sohaiba
     Yes thank you for your reply. To obtain the intrinsic capacitance parameters for spice netlists, I had to turn on a switch during LVS. Then I applied PVS-QRC to get that intrinsic parameters extracted.
    Regards
