  3. libxrender.so.1 problem
  • Subscribers 129
  • Views 14218
mhawary85
mhawary85 over 12 years ago
I am getting this problem when I run the library path editor in CIW. It says "/opt/cadence/installs/IC615/tools/dfII/bin/32bit/cdsLibEditor : error while loading shared libraries: LibXrender.so.1: cannot open shared object file: No such file or directory" !!!
 Does anyone know how to overcome this problem.
    You have a package missing on your OS. I checked on both an RHEL5 and RHEL6 machine - here's what I got:
    RHEL5> rpm -q -f /usr/lib/libXrender.so.1
    libXrender-0.9.1-3.1.i386
    RHEL6> rpm -q -f /usr/lib/libXrender.so.1
    libXrender-0.9.5-1.el6.i686
    So you need to install the libXrender package on the machine.
    Kind Regards,
  • mhawary85
    Thanks for the help, the error is gone.
