  3. Access to ADE-XL Results (Design Points)
  • Subscribers 132
  • Views 14404
mate0409
mate0409 over 12 years ago
Hi all,
following example:
I define a global variable Uin: 0:1m:10m and an output expression: out_cal =value("/Uout" 1m). After running the simulation i get 11 results (design points). Is it possible to access the simulation result of a specific design point? I want to use that result for an expression in another test (via calcVal() ).
I think about something like this:
value( out_cal "Uin" 0m ) or value( out_cal "Uin" 10m)
value( out_cal 1.0 ) for Design Point 1
 Thank you.
