  3. spectre mc simulation : how to gain disk space (option save...
  • Views 3846
spectre mc simulation : how to gain disk space (option save=selected/none...) but keeping the post-processing possible.
samung
samung over 13 years ago
I would like to reduce the disk area needed for a spectre simulation (example of a monte-carlo (transient) run 842 (cf. below)).
Command launched : spectre input.scs +log mc_log_file.log
Inside the input.scs, I can, indeed, decide to save or not some selected data => saveOptions options save=selected subcktprobelvl=2
If I do that, I can do my post-processing exports (example : export out_b_sensed=oceanEval("value(v(\"out_b\" ?result \"tran\") 2e-08)")), however, it takes much disk area than with the save=none option : 456 kBytes vs 216 kBytes
If I decide to put save=none, I reduce the disk area but, the post-processing is impossible =>
Error found by spectre during Monte Carlo analysis `mc1'.
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `saout_b_sensed=value(v("saout_b" ?result "tran") 2e-08)'.
Do we have a way to reduce the disk area with keeping the possibility to do the post-processing ?
Summary below :
1/ with (inside the input.scs) : saveOptions options save=selected subcktprobelvl=2
The biggest file is :
249916 Jul 25 12:31 input.raw/mc1_tran.tran  => size of 250 kBytes
...> du -sh ../842/
456K    ../842/
...> du -sh ./*
4.0K    ./cp_input.scs
0       ./du
356K    ./input.raw
4.0K    ./input.scs
4.0K    ./input.scs~
12K     ./mc_log_file.log
52K     ./monteCarlo
92K     ./pp238496.out
4.0K    ./spectre.fc
4.0K    ./spectre.ic
...> ls -lrt input.raw/*
504 Jul 25 12:31 input.raw/mc1.mcparam
5376 Jul 25 12:31 input.raw/mc1_finalTimeOP.info
684 Jul 25 12:31 input.raw/mc1_modelParameter.info
13152 Jul 25 12:31 input.raw/mc1_element.info
1484 Jul 25 12:31 input.raw/mc1_outputParameter.info
4647 Jul 25 12:31 input.raw/mc1_designParamVals.info
5264 Jul 25 12:31 input.raw/mc1_primitives.info.primitives
523 Jul 25 12:31 input.raw/mc1_subckts.info.subckts
1156 Jul 25 12:31 input.raw/logFile.tmp
2140 Jul 25 12:31 input.raw/mc1_tran.montecarlo
2148 Jul 25 12:31 input.raw/mc1_finalTimeOP.montecarlo
2152 Jul 25 12:31 input.raw/mc1_modelParameter.montecarlo
2144 Jul 25 12:31 input.raw/mc1_element.montecarlo
2152 Jul 25 12:31 input.raw/mc1_outputParameter.montecarlo
2152 Jul 25 12:31 input.raw/mc1_designParamVals.montecarlo
2148 Jul 25 12:31 input.raw/mc1_primitives.montecarlo
2144 Jul 25 12:31 input.raw/mc1_subckts.montecarlo
3275 Jul 25 12:31 input.raw/logFile
382 Jul 25 12:31 input.raw/artil.log
2/ with : saveOptions options save=none subcktprobelvl=2
...> du -sh ../842/
216K    ../842/
...> du -sh ./*
4.0K    ./cp_input.scs
116K    ./input.raw
4.0K    ./input.scs
4.0K    ./input.scs~
52K     ./monteCarlo
12K     ./pp238496.out
4.0K    ./spectre.fc
4.0K    ./spectre.ic
504 Jul 25 12:02 mc1.mcparam
12348 Jul 25 12:02 mc1_tran.tran
2468 Jul 25 12:02 mc1_finalTimeOP.info
684 Jul 25 12:02 mc1_modelParameter.info
13152 Jul 25 12:02 mc1_element.info
1484 Jul 25 12:02 mc1_outputParameter.info
4647 Jul 25 12:02 mc1_designParamVals.info
5212 Jul 25 12:02 mc1_primitives.info.primitives
523 Jul 25 12:02 mc1_subckts.info.subckts
1156 Jul 25 12:02 logFile.tmp
2140 Jul 25 12:02 mc1_tran.montecarlo
2148 Jul 25 12:02 mc1_finalTimeOP.montecarlo
2152 Jul 25 12:02 mc1_modelParameter.montecarlo
2144 Jul 25 12:02 mc1_element.montecarlo
2152 Jul 25 12:02 mc1_outputParameter.montecarlo
2152 Jul 25 12:02 mc1_designParamVals.montecarlo
2148 Jul 25 12:02 mc1_primitives.montecarlo
2144 Jul 25 12:02 mc1_subckts.montecarlo
3275 Jul 25 12:02 logFile
1331 Jul 25 12:02 artil.log
input.scs (extract) :
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=70  tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5  digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output"  checklimitdest=psf
mc1 montecarlo numruns=1 seed=12345 variations=mismatch sampling=standard  donominal=no scalarfile="../monteCarlo/mcdata" savemismatchparams=yes  mismatchparamfile="../monteCarlo/mismatchparam" mismatchscalarfile="../monteCarlo/mismatchdata"  savefamilyplots=no savedatainseparatedir=yes  firstrun=842 {
tran tran stop=20n write="spectre.ic" writefinal="spectre.fc"  annotate=status maxiters=5
subckts info what=subckts  where=rawfile
mcOptions options genmcdep=yes
log :
    ERROR (SPECTRE-8003): mc1_subckts: Error evaluating ocean expression `out_b_sensed=value(v("out_b" ?result "tran") 2e-08)'.
Thanks a lot.
P.
  • samung
    Well, as workaround, I am trying to archive the input.raw/ directories once the post-processing is done :
     tar -cjvf .../842/input.raw.tar.bz2 /842/input.raw/ --remove-files /842/input.raw/
    Nevertheless, it would be better to control the file size created during/after the spectre simulation.
    P.
    First of all, do you really need subcktprobelvl=2 ? That will save lots of currents - better to save just the terminal currents you need in your measurements (and I think ADE XL should set this up for you automatically).
    Secondly, in the "Save All" form (where subcktprobelvl etc is set), you could turn off the saving of model parameters, elements info, etc - this will save time and (a small amount) of disk space.
    Saving the mismatch data will also create quite a bit of data in general - and unless you really need it, don't save it.
    That said, with all of this, I think there could be some benefit in not keeping the simulation results once measurements have been made. ADE XL offers this choice via  Options->Save and you can turn off "Save Simulation Data".
    If you are not running all your jobs in parallel (i.e. nunruns>1), then spectre will also delete the individual points data (except the last) unless you have savefamilyplots=yes.
