  3. customize title block in cadence virtuoso schematic editor...
  • Subscribers 132
  • Views 16060
customize title block in cadence virtuoso schematic editor 165
apple419
apple419 over 12 years ago
Hi, cadence virtuoso users,
    Is it possible to customize or create own title block in virtuoso schematic editor 165? I don't really like the existing title blocks that come with the software.
    If yes, then what are the steps?..
Thanks a lot!
  • skillUser
    skillUser over 12 years ago
    Well, you could just copy a sheet from the US_8ths library and modify it as required...
    Also there are a couple of useful solution articles that you might be interested in: How to use customized sheets instead of default sheets from US_8ths library? and HowTo: Virtuoso Schematic: Sheet Creation and Customization
    Did you search in the Cadence Online Support website?
    The above solutions should answer your question.
    Best regards,
    Lawrence.
