  3. Ultrasim simulator Problem
  • Replies 12
  • Subscribers 133
  • Views 23087
archive over 19 years ago
I built a simple resistive ladder for voltage divider circut with componenets in analogLib. When I tried to simulate this circuit with Ultrasim simulator, the intermediate nodes failed to show the output waveform excepting ground and supply nodes. I added them in the outputs list,tried save all method but none of them worked. It happened with both SPICE and Spetre netlisting formats. I tried this simple circuit when a complex circuit failed to simulate properly. Hence now I find that the resistor is not identified properly in the Ultrasim simulation. Is there any known solution for this probelm??
Thanks in advance for your suggestions
Originally posted in cdnusers.org by gunturikishore28
    Well Not only resistor, capacitors also dont support node voltage expressions.
    Are you using "ultrasim -spectre yourNetlist.scs" ?
    Ultrasim by default assumes the netlist is SPICE.
    Originally posted in cdnusers.org by adbeckett
