  3. Spice to Spectre
  • Subscribers 132
  • Views 21619
Spice to Spectre
chaosatom
chaosatom over 12 years ago
 I have tried to follow these step for getting a diode in spice to appear in spectre, but I get errors:
 1. Convert the SPICE block using spp.
---This is the output:
 simulator lang=spectre insensitive=yes
subckt x1n4735a ( 1 2 )
//  The resistor R1 does not reflect
//  a physical device. Instead it
//  improves modeling in the reverse
//  mode of operation.
r1 ( 1 2 ) resistor r=3e+9
d1 ( 1 2 ) d1n4735a
model d1n4735a diode
+ is=7.526e-16              n=0.992                   bv=5.105
+ ibv=0.005                 rs=0.2338                 cjo=129.04e-12
+ vj=.46589                 m=.2767
2. Open any schematic, select Design -> Create Cellview->From
pin list, and type in the destination symbol and pin list.
 ----I opened an empty schematic and created a symbol (input and output ports labeled 1, 2)
3. From the symbol view, choose Design->Save As, and save it as a spectre
view. Alternatively, use the Library Manager to copy the symbol view to the
spectre view.
 ----I have copied symbol and view name to spectre.
4. Start Artist, and in the Setup -> Model Libraries form, include the path
to the converted text.
---I created another cellview. Instianted the spectre symbol for the diode. Went to model and attacted the file.
5. Set the model property on the block to be the same as the top-level
subcircuit name in the converted text. You will probably need to add the
model property. Just select the block, then choose Edit -> Properties ->
Objects. Next, Click on the Add button in the User Property section. For
"name", put "model", "type" should be "string", and you can leave the other
two fields blank. Under the Local Value on the Properties form, enter the
name of the top-level subcircuit.
-------Gave the local value of x1n4735. Ran a DC sweep
 I get this error:
WARNING (ADE-1065): No simulation results are available.
Delete psf data in /ti/home/vipul/cadence/simulation/test_circuit/spectre/schematic/psf.
generate netlist...
Begin Incremental Netlisting Aug 5 15:38:09 2013
Netlist Error: Cannot find any info on instance "I1" in cell-view "Mppt2" "test_circuit" "schematic"
Netlist Error: Some cell-views used inside this block could not be netlisted in analog context
End netlisting Aug 5 15:38:09 2013
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
...unsuccessful.
------ The schematic is empty, so should I put something in there? I am confused.
    You didn't set up the CDF for the cell  x1n4735. In step 5 you added a user-defined property with the model name, which won't be used...
    So, go to Tools->CDF->Edit CDF in the CIW, and set the CDF type to be Base. Set the cell name to be x1n4735, and then add a CDF parameter called "model" which you can give a default value of x1n4735, In the Simulation Information section, set the termOrder for spectre to be "1 2" and that's pretty much all you need.
    BTW, you don't really need to use spp these days - spectre should be able to read SPICE syntax directly (the spp translator hasn't been touched in about 10 years).
  • chaosatom
    Ok thanks, it works now.
    I also used this thread:
    /blogs/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade.aspx
    I was also making the mistake of editing the CDF of the instantiate cellview. Also, I just used my spice subcircuit model instead of converting to spectre.
    Vipul
  • chaosatom
    I got one more question if you don't mind. I can't seem to probe the current of my subcircuit diode. Although I can probe the current from VDC that I am supplying voltage from. I basically see a blank screen if I probe the current of my sub circuit diode. Am I missing something there? Thanks, Vipul
