  3. Changing the legened postion by default in viva
  • Views 16439
wgtkan
wgtkan over 13 years ago
Is there any way to change the legend position in viva so that it shows above the plot always? Every time, I plot a simulation, I have to go to graph, properties, and graph options to change the legend position from left to above.
Thanks in advance.
    envSetVal("viva.rectGraph" "legendPosition" 'string "above")
  • KoVe
    KoVe over 11 years ago
    How can I change the default legend position for an eyeDiagram?
    The default for a transient response is "left", but for an eyeDiagram the legend position is always "above".
    Koen
    Hi Koen,
    This changed in IC616 ISR9, as a result of CCR 1232703. There is no option to change the default behaviour - if you don't like it, you have to edit the graph properties afterwards. It's similar to histograms - these also have the legend "above" - usually because you have a single eye diagram or single histogram and so the above choice is more space-efficient.
    If you want this configurable, you should contact customer support for an enhancement request.
    Kind Regards,
