  3. about ahdlcmi simulation error
  • Subscribers 132
  • Views 14599
ROHIT DWIVEDI
ROHIT DWIVEDI over 12 years ago
 whenever i am using the passive components from UMC library for desighning it produses the simulation error
i am using spectre circuit simulator version 11.1.0.532.isr15 32 bit
ERROR(VACOMP-1008) cannot compile ahdlcmi module library. check the log file input.ahdlsimDB//3574_models_spectre_._._respp.va.respp_va.ahdlcmi/linux/. . /ahdlcmi.out for details.
if the compiler ranout of memory ,use setven CDS_CMI_COMPLEVEL 0; nad try again
(SFE-91) : Error when eloberating the instance respp_va. simulation should be terminated.
plz help me how to simulate my design.
    Did you look in the ahdlcmi.out log file like it told you to?
