  3. PSS and PNOISE Analysis
  • Views 15877
kapiljainwal
kapiljainwal over 12 years ago
I am simulating an Chopper stabilized folded cascode opamp. But I am getting som strange behavior at the output. First I am getting unnecessary zoroes in phase plot when I am doing AC analysis but on other machine circuit is showing proper output.
Second I am getting some convergence issues when I am doing PSS and PNOISE analysis. and When I am resimulating the circuit Then it is showing some different results as compare to previous time out put.
Please Help me if any settings problem is there or something else.
  • Tawna
    Tawna over 12 years ago
    Hi Kapiljainwal,
     We need more information to be able to assist you.
    1. What version of spectre are you using?  The command  spectre -W   will give this info.
    2. The problem statement isn't very clear.   Please - one issue at a time.  Provide exact error messages.  Describe clearly the setup you are using, etc.
    For questions like this, it may be best to contact Customer Support for assistance.
    best regards,
    Tawna
  • winniewang
    winniewang over 12 years ago
    More information please.
