  3. cdsRemsh ignores "ssh" setting .cdsenv
  • Subscribers 133
  • Views 4188
kitmonisit
kitmonisit over 12 years ago
I am setting up a Distributed Processing environment using cdsqmgr.
I have the following lines in my ~/.cdsenv
asimenv.distributed copyMode boolean t
asimenv.distributed remoteShell string "ssh"
asimenv.distributed loginShell cyclic "csh"
I found a cdsRemote.scr in /usr/cadence/IC610/share/cdsssetup/cdsRemsh and followed the instructions there. Somewhere in LINE 43 of this file, I see:
remoteSystem=rsh
#remoteSystem=ssh    # uncomment this line to configure for generic ssh
Since I do not have write privileges in /usr/cadence..., I copied cdsRemote.scr to my home ~/cdssetup/cdsRemsh because the instructions at the top of the file said so:
The default behaviour of the cdsRemote facility can be modified by
copying the file to a directory with a higher serach precedence
(such as $HOME/cdssetup/cdsRemsh/cdsRemote.scr) and then modifying
the copy.
And so I modified the copy to read:
remoteSystem=ssh
Checklist
I have done the following necessary setup:
  1. Add to my ~/.cshrc
    setenv LBS_CLUSTER_MASTER calvin
  2. Create a queue-config file with the following contents
    fast 2
    calvin 2
    hobbes 2
  3. Kill all cds... processes owned by root
    $ ps -u root | grep cds
  4. Run cdsqmgr as root
    $ su
    $ cdsqmgr ~/queue-config
Testing
Now, when I test using adptest, I get the following output:
BEGIN Analog Design Environment Distributed Processing Setup Test
Testing for existence of LBS_CLUSTER_MASTER variable...
    PASSED.
Testing opening of Analog Design Environment Job Server...
Launching Analog Design Environment job server...
Analog Design Environment job server has initialized!
    PASSED.
Please be patiend - the remaining portion of the test takes some time.
Testing job submission to host `calvin' on queue `fast'...
Waiting for ipc:-1 to terminate
    PASSED.
Testing job submission to host `hobbes' on queue `fast'...
connect to address 100.100.100.101 port 544: Connection refused
Trying krb4 rsh...
trying normal rsh (/usr/bin/rsh)
hobbes: Connection refused
Error (cdsWaitFor): command cdsRemshClient failed with status 1
Waiting for ipc:0 to initialize
    PASSED.
END Analog Design Environment Distributed Processing Setup Test
t
Checking my mail
I check my mail on /var/spool/mail and see something like this:
Debug: ExecCommand:
/usr/cadence/IC610/share/cdsssetup/cdsRemsh/cdsRemote.scr shell
hobbes ... <truncated> ...
Question
Why is the cdsqmgr still using the rsh to login to the executiong host, when I already set it to ssh in .cdsenv?
Why is the cdsqmgr still using the default cdsRemote.scr, when I already copied a modified file in ~/cdssetup/cdsRemsh?
    Don't know. Nothing obvious jumps out at me. Please contact tp so that somebody can debug this with you.
  • kitmonisit
    Thank you for the advice. What is TP? How do I contact them?
    Whoops, something got messed up when I posted that. I meant to say contact customer support. I think the focus of my cursor slipped as I was typing in the URL... and it ended up as "tp".
    Sorry!
  • vader
    vader over 12 years ago
    Can you try again after changing the permission of ~/cdssetup/cdsRemsh/cdsRemote.scr to include execution permission?
    chmod +x  ~/cdssetup/cdsRemsh/cdsRemote.scr
    Best regards,
    Teng-Kiat
