  3. verilogin problem: modules are imported twice
  • Subscribers 132
  • Views 15753
Howel
Howel over 12 years ago
 Hi All,
I'm importing some verilog files into  dfII library to generate a schematic to run a transistor level simulation.The library for standard cells are created first. When I use verilogin, it can proceed without errors but there is a weird problem, it will place each module twice, one with proper connections and one without any connections.
For example, following is a simple verilog file, containing only one inverter.
module test (A, B, VDD, VSS);
input A;
output B;
input VDD;
input VSS;
INHDV1 inv1 (.VSS ( VSS ), .VDD ( VDD ), .I ( A ), .ZN ( B ) );
endmodule
INHDV1 is a standard cell and it has ports VDD/VSS/I/ZN. But the imported schematic has two inverters, where one connects to VDD/VSS/A/B correctly, and the other has no connections at all.
I tried some options in verilogIn form and read the document. No clues. We are using IC5141usr6.
Could anybody give some suggestions?
 Howel
    Howel,
    I don't see this problem using IC5141 USR6. It works fine for me...
    Do you have a particular version of the digital simulators in your path? From UNIX, what do you get if you type "ncvlog -version" (I was running without ncvlog in my path).
  • Howel
    Very curious, the problem is gone after I switched to IC5141user5. Actually I'm using only ihdl from ic5141usr5 since this time I tried to use command line. After preparing the ihdl_files needed, I specify the path to call ihdl residing in 5141usr5, now everything is ok. Don't know why.
    The version for ihdl in 5141usr5 is 5.1.0 06/20/2007, and for 5141usr6 it's 5.1.0 10/28/2008.
    And ncvlog's version is 8.20-s024. ( But in ncvlog.log, it said 5.50-E115. )
    Perhaps there are some compatible issues in my environment.
    Thanks a lot,
    Howel
