  3. skill to plot waveform contained in a file into w-viewer...
  • Subscribers 132
  • Views 15782
skill to plot waveform contained in a file into w-viewer (could be VIVA)
azde
azde over 12 years ago
Posting in the hope that someone has a function they can share that will take a file (two columns of x, y data) and plot that in the active graph window.
Probably leverages this solution from CCS :
How to overlay waveforms created by function ‘drCreateWaveform’ in IC6.1.5 ViVA?
http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1bboMwFAXXwgKiazstJp-AeZiHUwgByg8iFSBCwBSRJnT1JQvonM_R0UAB28bqp2urpZNjdYMcCrXExDGx_4YOR1NoiGuq8OPUQhuQvR5qif5BR_AJBX15QrCGDo6dGIibPvc0uifIVyEd5TxspQRy72sJmNRbprOY49Scm8gJ5JOSxp7kzdWleDbWXCeCMCOebHpsuEfw_RKZu4-7MROSIHrhMq2z8HENW8M9l068t87Gyvt3scu_KXbXbAnyYSpxeLq6bXdCdc8eoxOtkaKAcOVQw9SPv7amK3-ZaVEi/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
If I don't hear back, I'll post my solution later next week..
    There is a function in the ViVA calculator called getAsciiWave which does this already, so there's no need to write anything.
     Kind Regards,
  • azde
    Thanks Andrew - that helped.
    Is there a way to set units on the x-axis?  ViVA doesn't let you overlay if the units don't match..
    One way of course is to dump the sim-generated waveform into a file and get rid of its units and plot that also using getAsciiWave..
    Thanks!
    Yes, you can use the code in solution 11609072 for this. From IC616 ISR3, you'll also be able to mark the axes as accepting any units ("flexible axes"), and this will allow different signal types to be plotted together more easily.
    The code in the solution allows you to register calculator functions for abSetUnits() and abSetXUnits() (the first does the Y axis).
