  3. Layer not showing in layer palette
  • Subscribers 133
  • Views 17361
MarkTown
MarkTown over 12 years ago
 hi,
    So a new layer was put into the tech file. I've looked at the tech file it appears to have been added correctly.
Layer is: NSD with a purpose of polygate. Problem it doesn't show up in the palette.
With code I can moved a shape from NSD.drawing to NSD.polygate. The shape has the display.drf look its suppose to have.
I can then select it and do a Q on it with the right info in the window, but the pulldown to change its layer doesn't have the
NSD.polygate in the list.  It would make sense that this palette is coming from the same list as entry layer palette list.
Any thoughts how I can correct this?
Mark
  • Quek
    Quek over 12 years ago
    Hi Mark
    Would you please try adding NSD layer into "leLswLayers" section in the techfile?
    Best regards
    Quek
