  3. Offset voltage measurement
  • Subscribers 130
  • Views 17235
kapiljainwal
kapiljainwal over 12 years ago
I am desiging a low noise, low offset opamp using chopper stabilization and ripple reduction loop.
I need to know how to measure the offset voltage. Is it related to montecarlo simulation ?
pls guide me.
  • Quek
    Quek over 12 years ago
    Hi kapiljainwal
    Actually I think any design parameter can be related to monte carlo. You should be able to find offset using the usual method of (output voltage - refernce voltage). It would indeed be good to run a monte carlo using ADE-XL to check on the possible range of variation.
    Best regards
    Quek
