  3. Nested Parametric transient Sweep in Cadence
  • Subscribers 132
  • Views 16286
chaosatom
chaosatom over 12 years ago
How do I perform nested parametric transient sweep in ADE of Vdd and Temp?
If not possible, how do I modify the ocean script after saving the file? Do I use the "for each" command?
Snippet of Ocean script:
"paramAnalysis("vdd" ?values '(1.2 1.35 1.5))
 paramRun()"
Vipul
    Hi Vipul,
    Type ocnHelp('paramAnalysis) at the OCEAN prompt (or in the CIW) and it will give an example of doing this.
    Or set it up in ADE, and then save an OCEAN script - simply sweep two variables in the parametric analysis UI and it will do a nested sweep. This will be covered in the documentation...
    Kindest Regards,
  • chaosatom
    Thanks. Just adding another paramanalysis made it work.
    paramAnalysis("temp" ?start -50 ?stop 100 step 50)
    Vipul
