  3. Tip of the Week: Use infotimes to define trans op point...
  • Subscribers 133
  • Views 15942
Tip of the Week: Use infotimes to define trans op point saves
archive over 19 years ago
By default, you can only annotate or print transient operating points at the final step of a transient run.  However, you can change this by use of the "infotimes" parameter in the transient options menu.
It is very easy to use:
* Fill in the "infotimes" field in the transient options form (e.g. "1u 1.5u 2u")
* Run the transient analysis
* Select Results/Annotate (or print) transient operating points
Instead of just annotating the final time operating point, you now get a pop-up menu that allows you to select which of the previous selected times (1u/1.5u/2u) the annotated operating point info applies to.
- Hugh
Originally posted in cdnusers.org by Hugh
    Great this would be of great value in analyzing transient behaviors in the circuit without plotting all the info.
    Shafi.
    Originally posted in cdnusers.org by shafi.syed
  • imagesensor123
    imagesensor123 over 14 years ago
        yes, we can do like you said above, and did you have a try to monitor a node capacitance during the transient simulation with the funciton "infotimes", let me know if you have some experience, thanks
    regards,
    zhenfu
    Zhenfu,
    The forum guidelines state not to append to old threads. Appending to 5 year old topics really doesn't make sense, especially when you're asking the same question in another thread. I have answered you there.
