  3. Ocean scripting - Plotting multiple expressions in different...
  • Subscribers 132
  • Views 1691
Ocean scripting - Plotting multiple expressions in different strips
PBabu
PBabu over 12 years ago
I need some help on this.
I'm simulating an amplifier for many corners and need to plot gain and phase response.
For the plots, I need appended plots (of all corners) of gain in one strip and phase (of all corners) in another strip.
I tried doing the following in my script:
Gain_plot=dB20(getData("loopGain" ?result "stb-stb"))
Phase_plot=phase(getData("loopGain" ?result "stb-stb"))
y=newWindow()
awvPlotWaveform( currentWindow(y) list(Gain_plot Phase_plot) ?expr list("Gain" "Phase" ) ?stripNumber list(1 2) )
However, when the gain and phase expressions are re-evaluated in an outer loop(not shown here), the plots are replaced.
I also tried using awvSimplePlotExpression and awvPlotExpression. What I understand is that these cannot be used to plot multiple expressions. Am i wrong?
Can anybody help me out with this?
Appreciate your patience.
btw, my version of icfb is 5.10.41.500.6.151
Prashant
  • PBabu
    Solved it.
    Indeed I was wrong about awvSimplePlotExpression.
    It works. This is what I did:
    x=newWindow()
    awvSimplePlotExpression( currentWindow(x) "Gain_plot Phase_plot" nil nil ?expr list("gain" "phase") ?stripNumber list(1 2) )
    I now get overlapped plots of gain and phase in 2 strips of the same window.
    Cheers,
    Prashant
