  3. mixed-signal AMS simulation error
  • Subscribers 132
  • Views 15120
apple419
apple419 over 12 years ago
   I was trying to do a simple mixed-signal simulation with AMS in Cadence ADE environment (6.15).
   In the setup there are two inverters. One inverter A has schematic view and the other inverter B has Verilog view. The Config view is created.
   In the hierarchy editor form, correct views are set (A has schematic view and B has verilog view).
In ADE, the ams is selected as the simulator. The ConnRules_3V_full_fast is selected as the connect rule. The OSS-based netlister with irun is slected.
   When I started a transient simulation, the simulation log shows the following error and the simulation stopped.
   irun: *E,BDOPT: Unknown option -rnm_partinfo
   Anyone have any idea what this error is about?  Is there anything I missed in the setup?
Thank you for the help!
Regards
  • apple419
    problem solved.
