  3. Is there a way in Verilog-A to know if transient noise analysis...
  • Subscribers 131
  • Views 16777
Is there a way in Verilog-A to know if transient noise analysis is run?
SharksFan
SharksFan over 12 years ago
Hi.  I'm running  IC6.1.5.500.12 with MMSIM 12.1.0.435.isr7.
I know the 'if (analysis("tran"))' Verilog-A statement can be used to select code to run when transient analysis is run, but how do I tell in Verilog-A if transient noise analysis is run?  Is there some other option for the "analysis" statement that isn't documented that covers transient noise analysis?
Thanks.
    No, but why would you want to? In general it's best to avoid analysis-specific code in VerilogA.
    The white_noise, flicker_noise etc functions will not do anything in a normal transient, but will generate noise in a transient noise - so that's normally all you need.
  • SharksFan
    I want to know if transient noise has been selected because if the model is written for adding noise in transient using the  $rdist_normal function and then the user also turns on transient noise, enabling the white_noise and flicker_noise functions, then noise will be double generated and incorrect.
    I also submitted this to Cadence Support and an enhancement CCR # 1192702 with R&D was filed.
    Fair enough. That's a good reason.
