  3. Spectre adexl results to sdb/pcf file?
  • Subscribers 132
  • Views 942
DeepG
DeepG over 12 years ago
I'm new to spectre adexl. I have a test whose output expression values at various corners I need to use as inputs to another test. I'm not able to generate an sdb file /pcf file as the output which I can read into the second test setup. Can someone please let me know if this can be done or if there is an alternative way to do this ?
