  3. How to pass parameters to a VerilogA module
  • Subscribers 132
  • Views 17955
RFStuff
RFStuff over 12 years ago
 Dear All,
Can anybody please tell how to pass parameters to a VerilogA module.
I tried with CDF parameters like normal symbols but it did NOT work
     Well, not sure what you did - because that should work (and always has worked). Did you define the parameters in the VerilogA module?
    Perhaps you could show the VerilogA module, what the edit properties form looks like in the schematic, and also what the instance line looks like in the resulting spectre netlist?
  • RFStuff
    Dear Andrew,
    Sorry,I was trying to make entry into CDF form like one does for making netlist to symbol.
    Later, I found that the parameter entry is simpler ( there is no need to play with CDF parameter entry).
    In CDF parameter View--> VerilogA, all the declared parameters options come.
    Kind Regards,
