  3. Monte carlo on a verilog A custom macro model based on device...
  • Views 16250
Monte carlo on a verilog A custom macro model based on device instance not subckt instance
Fabb
Fabb over 12 years ago
 I am developing my own macro model in verilogA
 module test1 (p1,p2);
endmodule
 Then I use a model card approach to manage the parameters and their variations:
 simulator lang=spectre
section TT
endsection TT
section LL
endsection LL
section STAT
               parameters _param1=1
               parameters _param2=1.1
               statistics {
                              process {
                              mismatch {
                                            vary _param1 dist=gauss std=5 percent=yes
                                            vary _param2 dist=gauss std=13 percent=yes
               include "modelCard.scs" section=MODEL
endsection STAT
section MODEL
               ahdl_include “path/modelTest1.va"
               model modelSymbolName test1
                              + param1 = _param1
                              + param2 = _param2
endsection MODEL
Then I got the following error
Error found by spectre during Monte Carlo analysis `mc1'.
    ERROR (SFE-2458): dut Instance 'I5' should be subckt instance not device instance (statement ignored).
With I5 is the instance name of modelSymbolName
Is it means that to run a monte carlo, the model cards must be written with a subckt calling the model itself ?
Fabrice
    The "dut" parameter for monte carlo essentially is a way of specifying which instances have monte carlo applied. In general only subckts can have mismatch applied, because the unique parameterization is done per subckt instance rather than primitive instance (for example, see Recommended Spectre Monte Carlo modeling methodology)
