  3. settings for Verilog Import
  • Subscribers 132
  • Views 15799
navi2582
navi2582 over 12 years ago
Is there a setting in the VerilogIn to include the POWER_PINS during the schematic creation?
`timescale 1ns/1ps
`celldefine
`ifdef POWER_PINS
module Std_cell_def (Y, A, B, C, VDD, VSS);
inout VDD;
inout VSS;
supply1 VDD;
supply0 VSS;
`else
module Std_cell_def (Y, A, B, C);
`endif
output Y;
input A, B, C;
  specify
    // delay parameters
    // path delays
  endspecify
endmodule
`endcelldefine
    The VerilogIn form doesn't appear to allow you to define macros although the underlying ihdl executabled does (type ihdl -help at the UNIX prompt). So either use ihdl, or you could specify a second file to import (define it first) which contains:
    `define POWER_PINS
    Probably worth contacting customer support so that we can file an enhancement CCR on your behalf to support -DEFINE from the Import Verilog form.
