  3. Simulation/work folder
  • Subscribers 132
  • Views 3813
HamidKhatibi
HamidKhatibi over 12 years ago
 Hi
Does anyone know in which file the simulation folder (Simulator host directory) is set?
Each time I start ADE L I have to go in Setup and set it to the desired folder.
Thank you in advance
Hamid
  • skillUser
    skillUser over 12 years ago
     Hi Hamid,
    Your ~/.cdsenv file can set this.  Here is the default entry:
    asimenv.startup projectDir      string  "~/simulation"
    So you would set this to another location as required.  The .cdsenv file can exist in
    other locations, so the home directory is one place this could be defined.  It is also
    possible to make such a setting through SKILL:
    envSetVal("asimenv.startup" "projectDir" 'string  "~/simulation")
    Hopefully this answers the question for you?
    Lawrence.
  • HamidKhatibi
    Thank you so much Lawrence.
    Hamid
  • HamidKhatibi
    I do not have that line in my .cdsenv. The only related one is:
    asimenv.startup simulator "spectre" .
    I will add the line that you mentioned in the file to see what happens.
    BTW, I have no idea about SKILL, where shall I edit it?
    Best
    Hamid
  • HamidKhatibi
     I added that line and it worked perfectly.
    Thank you so much,
    Hamid
