  3. issue with (* cds_inherited_parameter *)
  • Subscribers 132
  • Views 16563
Fabb
Fabb over 12 years ago
 I am developping a verilogA model and I would like  to implement a statistacl block for montecarlo purpose.
After few search on community cadence, I found that  I need to use (* cds_inherited_parameter *).
Nevertheless while using it (i.e (* cds_inherited_parameter *)), I got the following Warning
Warning from spectre during AHDL read-in.
    WARNING (VACOMP-1116): VERILOG-A PERFORMANCE WARNING:
Warning from spectre in `moldeName':`I29', during hierarchy flattening.
    WARNING (SFE-32): "/moldeName.va" 62: Duplicate specification for parameter `version' (using last value specified).
    WARNING (SFE-32): "/moldeName.va" 62: Duplicate specification for parameter `radius' (using last value specified).
        Further occurrences of this warning will be suppressed.
    WARNING (SFE-30): "/moldeName.va" 62: I29.moldeName: `RA0_var' is not a valid parameter for an instance of `spitt behavioral'.  Ignored.
    WARNING (SFE-30): "/moldeName.va" 62: I29.moldeName: `RA0' is not a valid parameter for an instance of `spitt behavioral'.  Ignored.
Is someone could help me.
Fab
    Fab,
    Could you post the relevant bit of code and the version of spectre you're using? It's hard to guess what the problem is without seeing an example (at least snippet) of code...
  • Fabb
    Andrew,
    Find bellow the pieces of code
     model Card skeleton
    section STAT
         parameters RA0_var = 0
         statistics {
               mismatch {
               vary RA0_var dist=gauss std=10 percent=no
              include " cornerFile.scs" section=MODELS_CORE
    endsection STAT
    section MODELS_CORE
         ahdl_include "../myModel.va"
         subckt symbolName1 (pin1 pin2 pin3) // symbolName1 should be identical to symbol name
               // CDF parameters, real values set in the instance through CDF
               parameters radius = 9999 initstate="P"
               local_I_0 (pin1 pin2 pin3) device1 radius=radius initstate=initstate
         ends mtjSttPe
         model device1 myModelName
               //techno parameters
               + RA0 = effRA0
    endsection MODELS_CORE
     I also tried to use an inline subckt instead of a basic subckt, but with the same result
    Then verilogA file
    module myModel(p1, p2, p3);
       (* cds_inherited_parameter *) parameter real RA0_var=0.0;
         localparam real RA0eff = RA0 + RA0_var;
            parameter real radius=90n;
    And a CDF is defined, link to the symbol of symbolName1 , where radius is defined but nither RA0_var nor RA0
    Then  I have the following WARNING
    Warning from spectre in `spitt':`I29.local_I_0', in `device1':`I29', during hierarchy flattening.
        WARNING (SFE-32): "myModel.va" 62: Duplicate specification for parameter `radius' (using last value specified).
        WARNING (SFE-30): " myModel.va" 62: I29.local_I_0.spitt: `RA0_var' is not a valid parameter for an instance of `spitt behavioral'.  Ignored.
    And in MonteCarlo, RA0_var doesn’t change.
    I suspect a problem between verilogA - CDF -  spectreNetList
    Fabrice
    Fabrice,
    Unfortunately you've not included the bits of the model/files that actually show the problem - there's no reference to "spitt behavioral" in there anywhere. I just tried a simple exampe and it worked fine.
    If you can't share the complete example here (and I can understand why that might be), please go to customer support.
  • Fabb
     Andrew,
     I finnaly understood the issue. The two following statment are incompatibles:
    (* instance_parameter_list ={parameter1, parameter2, .... } *)
    Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} (* cds_inherited_parameter *)
    which generates the bug.
    I found a workarround by avoiding to use  (* cds_inherited_parameter *) in the .va code.
    Fabrice
