  3. Error when trying to add stimuli in virtuoso
  • Subscribers 133
  • Views 15514
madhanmo
madhanmo over 12 years ago
I create a basic inverter and launched ADE L and tried to add the stimuli for the circuit and it comes up with the following error
*Error* Could not find source, vdc, in analogLib.
I am using NCSU cdk 1.6 beta(latest version as of now) some one please guide me on how to solve the above error
  • tempVar
    tempVar over 12 years ago
    I am having the same problem except instead of vdc, it is vbit and vpulse. I am trying to figure it out as well, have you found a solution?
  • tempVar
    ***Before changing your cds.lib file it is better to back it up (using cp command)***
    Finally, fixed it! I had to go to my cds.lib file and enter: DEFINE analogLib $CDSHOME/etc/cdslib/artist/analogLib
    For you the environment variable $CDSHOME might be different.
    To check what it is first type: env | grep CDS
    Check which variable points to the directory /dfII and that will be your variable. Just replace that instead of $CDSHOME.
