  3. multipart path with conics
  • Subscribers 132
  • Views 15478
Mauricio78
Mauricio78 over 12 years ago
I'd like to create a multipart path with conics. Right now, the form only allows me to use rectangular shapes for it. Is there a way to do this?
  • skillUser
    skillUser over 12 years ago
     Hi Mauricio,
    The rodCreatePath() function only supports subrectangle shapes (or other path shapes based on the master path).  To my knowledge there is no ROD support for conic, donut etc. shapes, only polygons, rectangles and paths.  Are you trying to create circular cut/via shapes?
    Perhaps if you provide some more detail some suggestions could be made?  Which version are you using, by the way?
    Lawrence.
  • Mauricio78
    Hi Lawrence,
     yes, I'd like to create circular cut/via shapes. I'm using IC6.1.5.
    thanks
    Mauricio
  • Mauricio78
    hi Lawrence,
     what if I want to create a multipart based on polygons instead of rectangular shapes. can I do that?
    thanks
    Mauricio
    No. You could create a fluid Pcell instead (there's an app note on how to do this on support.cadence.com - although the examples in the app note are not fantastic).
    regards,
