  3. saving verilog-a triggers compilation instead of just syntax...
  • Subscribers 132
  • Views 15106
saving verilog-a triggers compilation instead of just syntax check
danmc
danmc over 12 years ago
 For some reason that I do not understand, when I open up a verilog-A view from the library manager, make some edits and then exit, instead of just running the normal verilog-a syntax check, it seems to want to compile the ahdlcmi stuff giving me a mylib/mycell/veriloga/veriloga.va.ahdlcmi/ directory with the compiled model in it.  I don't remember changing anything, but it just started happening and I've used verilog-A quite a bit for more than  a decade in the cadence environment.  Suggestions?
-Dan
    Dan,
    I had a hunt around and can only find it with some old data - so I think it used to happen with an old version of MMSIM. Are you accidentally using an old MMSIM version? What version are you using? (type "spectre -W")
  • danmc
    You were on the right track Andrew.  Turns out that the environment variable we use to pick MMSIM version was set incorrectly and our deployment system then told the IC tools to use the super old spectre that was bundled with it (spectre-5).  Fixing that to point to a much more modern MMSIM made the issue go away.
    -Dan
