  3. Cadence IC 6.1.6 license error
  • Subscribers 129
  • Views 15950
likelike
likelike over 12 years ago
To whom it may help
Recently, we are downloading and installing the newest version Cadence (IC6.1.6 and MMSIM 12.1...etc) from the europractice-ic, however, we get an error message:
 \o *ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature "111".
We have double checked our license sever setting , and believe it is fine.
Becase we can still use Cadence IC 5141 and Cadence IC 6.1.4, they all working fine.
But based on the same license setting, we can not invoke the Cadence IC 6.1.6
Below is the CDS.log message:
\# Program start time UTC 2013.11.01 17:07:57.985
\# Local time Friday 1 November 2013, 5:07 pm
\o Program:        @(#)$CDS: virtuoso version 6.1.6 05/03/2013 15:09 (sjfnl155) $
\o Hierarchy:        /home/esdcad/software/cadence/linux/IC6.16.005/tools.lnx86/dfII/
\o Sub version:        sub-version  IC6.1.6.101  (32-bit addresses)
\# Host name (type):    xinyi0718.ecs.soton.ac.uk (x86_64)
\# Operating system:    Linux 2.6.32-358.23.2.el6.x86_64 #1 SMP Wed Oct 16 11:13:47 CDT 2013
\# Linux /etc/issue:    Scientific Linux release 6.1 (Carbon)
\# Linux /etc/issue:    Kernel \r on an \m
\# X display name (WxH):    :0.0 (3360x1050)
\# Available geometry:            TL(0:25) BR(3359:1024)
\# X server:            Scientific Linux
\# Depth of Visual (Root):    24 (24)
\# Number of Planes Used:    24
\# X version:        11.0 (vendor release 11300000)
\# X resource pool:    base 0x4000000, mask 0x1fffff (2097151), shift 0
\#             current id 0x0, current max 0x1ffffa (2097146)
\# Max data seg size:         unlimited
\# Max process size:         unlimited
\# Initial sbrk value:            382 MB
\# Available memory:         47,519 MB
\# System memory:         48,715 MB
\# Maximum memory size:          3,750 MB
\# Max mem available:          3,750 MB
\# Initial memory used:             36 MB
\#        process size:            360 MB
\# Qt version:        4.7.2
\# Window Manager:    gnome (metacity)
\# User Name:        root
\o Working Directory:    xinyi0718.ecs.soton.ac.uk:/home/kl/design/IBM8RFradiofiber
\# Process Id:        5406
\o
\o COPYRIGHT © 1992-2013  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           © 1992-2013  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\# Available memory:         47,518 MB at UTC 2013.11.01 17:07:58.072
\# Memory report: on exit             37 MB, process size 363 MB at UTC 2013.11.01 17:07:58.073
\# Memory report: peak usage          37 MB, process size 363 MB
Any suggestion regarding this error ? Do we need to renew our license to specific include the Cadence IC 6.1.6?
    Each time you update to a new major version, you need to update your licenses. This can be done via the Software Update link at the top of the page on support.cadence.com. Note this is not just for IC releases, but for all release streams that you may be using.
    The version number of the license feature in the license file has to be greater than or equal to that expected for each release. This is to ensure that software updates are only available to customers on subscription or maintenance contracts.
    Kind Regards,
