  3. Bindkey for layers below mouse cursor
  • Subscribers 130
  • Views 16066
bdjones1
bdjones1 over 12 years ago
At a previous company I had a bindkey (Shift+Home) that would display all layers below the mouse cursor.  This called a custom Skill function from the PDK, and I've been unable to replicate it or find a similar function.  Any suggestions on how to implement this?
Thanks!
Brian
  • wschwab
    wschwab over 12 years ago
    Hello Brian,
    In IC615 and IC616 exists an assistant (Window -> Assistants -> Dynamic Selection) which shows all shapes under cursor hierarchically in an assistant window..
    By typing ctrl <key> h you can freeze the display of the assistant window and select a shape there (if its in edit mode).
    Werner
  • bdjones1
    Thanks Werner!
    Unfortunately I'm using an old process in 5.1.4.  The technologies that had this bindkey enabled were also in 5.1x, so I know it's possible.  Any thoughts on how to list the layers under the cursor in 5.1.4?
    I'll definitely give that a shot in IC61x though!
    Brian
    Brian,
    How about this? I just threw it together (so not too much testing):
    /* CCFlayersUnderCursor.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 07, 2013
    Modified
    By
    Display the layers under the cursor - assume that
    you'd call this from a bindkey. This is not needed
    in IC61X since you have the dynamic selection assistant,
    but might be useful in IC5141.
    Call:
    CCFlayersUnderCursor()
    SCCS Info: @(#) CCFlayersUnderCursor.il 11/07/13.18:52:07 1.1
    procedure(CCFlayersUnderCursor()
      let((point overlaps win cv shape lpps
          (lppsUsed makeTable('lppsUsed nil)))
        win=hiGetCurrentWindow()
        when(win
            cv=geGetEditCellView(win)
            point=hiGetPoint(win)
            when(point
              overlaps=dbGetTrueOverlaps(cv list(point point) t 32)
              ; Collect the layer purpose pairs used in a table
              foreach(overlap overlaps
                shape=if(listp(overlap) car(last(overlap)) overlap)
                when(shape~>lpp
                    lppsUsed[shape~>lpp]=t
              ; Sort into alphanumerical order based on layer then purpose
              lpps=sort(lppsUsed->?
                lambda((a b)
                  case(alphaNumCmp(car(a) car(b))
                    (1 nil)
                    (-1 t)
                    (t minusp(alphaNumCmp(cadr(a) cadr(b))))
              ; Convert to colon-separated strings of layer and purpose
              ; and then display in a list box
              lpps=foreach(mapcar lpp lpps buildString(lpp ":"))
              if(lpps then
                hiDisplayListBox(
                  'CCFlayersUnderCursorListBox
                  "Layers under cursor"
                  lpps
              else
                printf("No shapes under cursor\n")
  • bdjones1
    Perfect!  I haven't tested it much, but it works out of the box.
    I actually prefer to just print the layers to the CIW rather than display in the box, so I added a flag noBox to skip the display list box, and a simple printf("%L\n" lpps) after the if(! noBox) block.
    Many thanks!!
    Glad I didn't spend too long doing a fancy form - I originally had it printing to the CIW too and thought I'd just add a simple form to display the results. Anyway, glad it does what you want!
